How could I modify the Album content in such a way this one is being considered by search engines?
For Pages,Posts, everything is ok. Modifying the Album description doesn't improve the result.
Please see the Wordpress SEO screenshot for a better understanding of what I am trying to explain ;-)
Thanks in advance for your support,
You can't modify it easily. All content for Album is loaded via JavaScript with data in JSON.
I know many users are obsessed with SEO plugins and that is nice that so many people worry about their content:-) But in case of albums many people is also concerned about their photos will be stolen by google(and everyone else). When we developed album part, protection of photos wasn't our main idea, but now I can see it as advantage ;-)
But back to topic to make this content indexable and still working as it should you will have to print all the data of album photos/videos in some kind of
<div>
with setvisibility: hidden;
in template. That will give search engines access to it.Next you will have to remove all of it(or maybe not) with JavaScript just before script will run to prepare album.
It is not very hard but it is lot of work which I won't do for you, in any case not till we release new theme(2-3 weeks). So if you have some coding skills and really need it then you can do it :-)
Thanks for your fast and precise answer (as usual :-))
Not sure I will have the expertise to do this coding, but I will try anyway as for my concern SEO on these albums is more important than "preventing" the content to be stolen.
Kind Regards
Do you think that creating a new post per album which will contain a full description as a content and a link to the album page would be a workaround for it? Or would it be in a way considered as duplicated content by search engines?
Kind Regards,
As for now as there is no content visible in albums(for search engines) it won't be duplicated at all. After we will add "SEO support" then maybe ;-)
Keep on the great work :-)
I am now in a middle of preparing update. I just ended making album to be visible to search engines. However SEO plugin still says that it doesn't see keywords in content. I think it is cause of that, that it looks for it in editor, that is disabled for albums. So it will be fake report even if keyword will exist in names and descriptions of photo:-)
If you have any suggestions please add them now ;-)
This issue have been fixed in new version. You can download it on themeforest : http://themeforest.net/item/hypershot-photography-portfolio-wordpress-theme/3391790
