Hello again,
About the RSS feed display content update you made, everything works fine for readers like Feedly, but almost working for Flipboard. In fact, the (image) content is not displaying for Flipboard, only the title and text is displayed.
I found the complete protocole made by Flipboard
http://flipboard.com/rss-feedI want to know if you can tell me (show me) what I have to do exactly to figured out this.
Thanks again!
Best
Well I don't quite know much about RSS, I don't even use them personally so we just adjusted what our users suggested. I can tell you where is RSS code filter, it is in
hypershot/advance/utilities.phpline ~904: I think image should be displayed in Flipboard, as we send standard HTML here(maybe it is just hidden by them), but maybe if anyone would go into documentation you linked, we will find something that is needed to show images.Edit: I gave code from our new theme;-) Fixed now
I understand what you mean about this tweak investigation, I hope that someone else will be helpfull to find out what can we do precisly to optimize this.
Thanks for your response ;-)
Best.
figuretag will fix it like their example You can try it if you have access to live preview on Flipboard :-)With regards.
