<?php //socials $visible_icons = $apollo13->get_option( 'social', 'social_number_of_visible' ); if( (int)$visible_icons > 0 ){ $icons_set = $apollo13->get_option( 'social', 'social-icons-set' ); .... ... ... if($has_active){ ?> <div class="socials"> <span class="static"><?php _fe( 'Follow' ); ?></span> <div class="visible"> <div class="slide"><?php echo $soc_html; ?></div> </div> </div> <?php } } ?>
.js .socials .visible{ display: block; }
Unfortunately not. This would be deeper theme customization, which we don't do(free or paid) as we don't have time and man power for that.
I managed to move the social icons to the footer
I just cut (!) it from header.php out of the content < div > and put it in footer.php in the content < div > (on the place, I'd like it to be).
After this, I adjusted the css and some more .socials properties to get what I want.
Now it looks great
Thanks for that:-) "Thanks for being kind", like Mike Falzone once said ;-)
Copied the paragraph you mentioned, but in the footer only the word social appeared...
