Since you really helped me out with the side bar, I figured I'd ask you one other thing Is there any way to delete the 'triangle' directly below the 'show info' toggle in the 'info above header bar'? Can't seem to find it in the stylesheet..
The custom css to get rid of the triangle worked really nicely for me. Unfortunately, today the triangle came back). The custom css is still there. I was wondering if you could come yet again to the rescue?
The little triangle shows up when I set 'enable thumbnails'. I would love to have the thumbnails as they are, but without the triangle. thank you so much!
The home page is a good example of a slideshow without thumbnails = no triangle. The engagement page has thumbnails (I like them there :-)) and then it has the triangle.
Use this Custom CSS
.hide-switch {
With regards.border-top: none;
Thanks again mate.
Excellent theme and excellent support. You guys got a good thing going on here
maybe my question fits in this thread. Is there a chance of getting a small picture in the info text?
Best regards
Stefan
<img src="your_img.jpg" alt="" />.With regards.
thx!
Here is the little guy:
http://www.life-beautifully.com/
Thank you *SO* much!!!
Ugh! SO sorry, I must have hidden it while playing around. Here is an example:
http://www.life-beautifully.com/album/engagement/
Thanks so much!
Ananda
For this one you have to use this CSS With regards.
http://www.anandalima.com/album/wedding/
(note the diff address because I went live :-))
Sending you a donut plus coffee to help with the long hours answering all these questions!
Thanks for Coffee, and donut, just bought one:-D
I can see that you didn't close comment section before this CSS rule, and that is why it is not working: With regards.
