Hey, Basically, all I want to do is remove the header/title section that is used in the default template for the home page only. I want to keep the header/title for all my pages except for the home page. So, I don't want to hide it using CSS.
I've created a custom template page as 'home-page.php' and selected it under template selection. Nothing seems to change. Can you tell me how I can do this.
Thanks David
Still You can use CSS to hide it only on home page, cause every page have specific class in
<body>element so you can target specific page.If you wish to overwrite default
home.phpfile then:1. use child theme http://apollo13.eu/docs/beach/#!/modification_of_theme
2. copy original
home.phpto child theme.3. Edit it :-)
This way you wont lose any changes on theme update.
The reason why I don't won't to hide the css is because I want the image I have on the front page higher up on the page and I don't want to use a negative top margin in css because when the screen size is smaller it overlaps.
Any ideas why the child home.php modifications aren't working?
Try breaking home.php in child theme, then we will know if it works or not :-)
Btw what have you changed?
I could help you more if you post live link and screen shot to visualize your desired effect.
If you still will have problems please send me temporary access to your WP so I could check there what is going on? Send it here on forum via private message(click on my nick and there you will find option to send message) .
I've attached a screenshot because I'm building the website locally on my computer.
You see the top 'home' title and the line beneath it. I want to remove that section so that I can have the image at the top of the page.
I assume that removing the following code from the top of the child 'home.php' file that it would remove the dynamic title that shows up at the top of the page:
<?php a13_blog_info_bar() ?>
This does nothing to remove the title....
I'm confused.
Even if I delete everything in the child home.php file nothing changes on the page....
Also, I have a static page set as my front page.
Sorry for confusing you, but now I know you are using static page. Instead of coping
home.phpcopypage.phpand change it in this way in child theme:Change: to: This should do the trick.
