Currently with the bricks style of gallery display when you click on an image it opens in a larger gallery view. My client wants the bricks style gallery display but with no images opening in the larger gallery view. Is this possible, or do I need to create a separate page?
You will have to switch to uncompressed scripts http://apollo13.eu/docs/hypershot/#!/advance_menu_use_compressed_js_amp_css
And next go to
hypershot\js\uncompressed\script.js
line ~1679change: to: With regards.
Check this topic http://support.apollo13.eu/discussion/comment/4253#Comment_4253 Be sure to read till last answer :-)
