Slow Site
edited December 2011 in Airlock Posts: 95
Hi again
actually i notice that my Site is really slow on building the theme during the navigation on my Site.
One Example is that when i navigate with arrow or through the Menue and so on. Firstly it expands my top Submit Dropdown Menue and than switch back.
And sometimes when i navigate through my site you first see the Undressed Side with pictures and text only and a second later it builds the Theme Design around it.
Sorry, Its a littlebit to fast to make a Screenshot to show it. Hope you understand it
It dont looks so smooth like your Site on themeforest.
Any Idea ?
thanks
    Menu - is divided in smaller menus after everything is loaded(without images).
    Unstyled content - Switch off night day switcher.
    Is disabled now but is the same.
    My Dropdown Panel on Top opend fast and go back agaain and also the site sint smooth
    thanks
    Didn't notice anything. Try ctrl + f5 on your site, and start cliking next pages. There is no style "jumping" when switcher is off.
  • this is the problem with the website design.
    i told apollo13 to implement some jquery site loader with the theme as an update.
    Yes it might be.
    My site is actually very slow.
    Dont know why. I disabled the most of my plugins but no change.
    anyway will change the theme ;-)
