Got few more questions.
Is there a chance I could have only one column in a blog post? Cannot figure it out. Shortcodes only offer 50% etc.
I need to insert one image, then some text, then image again and so on - it is quite difficult to read with two columns.
Also, when I inserted couple of images each of them created this strange light empty frame - see screenshot.
Thanks for help.
David
Show screen shot:-)
http://dbwebtest.eu/onecolumn_blog.jpg
Well, I think I got that - I just tried to resize the browser and it went to one column...
Any chance it could be one column all the time even on these higher res displays?
What about that white frame?
Just hover over the images - I've inserted them as an Image with lightbox using your shortcode.
No worries about the time, gotta get some sleep too. :-)
OK, I'll switch the Maintenance off tomorrow morning, have to leave it on for the night.
David
I really like it otherwise and wish to keep it but something must've gone wrong in this case.
Check that post from admin panel. All of those images are rectangular landscape mode.
Also pay attention to Link dimensions, you can even delete it.
There is also other solution - add this custom CSS It is only not tested and might affect other pages so to be safe use this one instead;-) : Hope that helps.
It still doesn't work though - the preview in the post is 600x400 (which is the image size I uploaded in the first Image line), when you click on it it goes full original size 1500x1000 (uploaded in the URL line).
But the preview still has that white hover border and it does not align right.
I tried to delete dimensions or change them but it did not help.
Anyway my custom CSS will fix it - use it.
Anyway, that CSS worked, thanks.
I can always take a look(but it will be in few hours).
