Move Header
edited May 2013 in Spaceship Posts: 4
Hi
first of all thanks a lot for this great Theme i*m relly happy with it ^___^*
My Question: Is it possible to move the Header from the Top to the bottom ?
    Hello, and thanks for kind words:-)
    This would be unsafe modification but if you wish to try it use this custom CSS:
    #root > header {
    bottom: 0;
    top: auto;
    it works fine Thanks. but the problem now is the dropdown menus are not visible !? how can i change the direction ?
    Yeah, that is what I call unsafe modification:-)
    Try this cusotm CSS:
    #access > ul ul{
    bottom: 100%;
    top: auto;
    WIth regards.
    fantastic it works great :) thanks for the great support
    If you are happy with this theme please don't forget to rate us on ThemeForest - it helps us a lot! Thanks!
    Done !
    Thank you again
