Airlock blog Gallery
edited May 2013 in Airlock Posts: 2
Hello. I tried to found the answer in the forum but i did not find it.
I would like to replace the little circles (how appears depending the number of pics) with only 2 arrows (next - pre).
How can i do it ?
www.n-e-t-e.com
thanks a lot for your help.
Jorge
    Hello
    Go to file airlock\common\js\scripts.js line ~266 and change
    buildArrows : false,
    to:
    buildArrows : true,
    buildNavigation : false,
    Don't worry about white spaces
    Next unpack this ZIP file that I have attached and copy whole directory images to
    airlock\common\ and then you will see arrows.
    zip
    zip
    arch.zip
    6K
    you are the best :)
    Thanks a lot :)
    Regards from Nîmes in the south of France
    Thank a lot for kind words:-)
    Have a nice day and If you are happy with this theme please don't forget to rate us on ThemeForest - it helps us a lot! Thanks!
