Hello Apollo 13,
It looks like album's pictures are always covered by the menu and the footer, doesn't matter wich fit option is used. Am I wrong? There is no fit option like the hypershot's one, where the whole picture is displayed between top menu and footer?
OK, just found the answer :
http://support.apollo13.eu/discussion/comment/2256#Comment_2256Hope you'll give us same option as Hypershot fit small images one!
OK if you want to cancel effect on smaller screen widths add this custom CSS: This should return normal behaviour.
http://www.photographe-mariage-grenoble.pro/
But in portrait mode, there is too much space between the images and the header and the slider. isn't it possible to have the same effect than hypershot : header, picture and footer visible?
By the way, the glass effect button is still visible on mobile even if I've setted it to no in glass effect option panel.
Thank you very much for your help!
.glass-switch {With regards.display: none !important;
You can try to alter styles if you like, it is your theme now :-) But SpaceShip looks like this, and it has its functional purposes:-)
OK! But is it possible to reduce the space between image and header and image and footer? And what CSS should I alter?
Thank you for the galss effect css!
50%to other value. However by default it is set to100%.Good luck!
