Padding under the home page slider
edited May 2013 in Beach Please Posts: 46
This might be my last question before I release my site to the public. :-)
I've got some text under the slider on the left side and tabs on the right. See the attached picture.
I need to put them at the same level - the text is too close to the slider. If I use   the text goes lower but so do those tabs. I'd love to have them next to each other, leveled and possibly at the same distance form the slider as the tabs are now.
Would you have any CSS for me please? ;-)
Thanks a lot for help!
David
    bruno7 said: This might be my last question
    LOL, "might" :-) Heard that story before;-)
    I understand you use there column shortcodes? Could you post live link?
    There is a chance you left too much white space after opening of shortcode. If that is the case, remove any white chars after opening of shortcode.
    I think I've got it right - don't see any white space there.
    It's live for a while now:
    davidbauer.cz
    Well, I actually found some white thing - got a rid of it and it looks much better now, see for yourself. ;-)
    Thanks.
    David
    OK, the site is live and kicking.
    If you want, check it out - and I welcome criticism and/or help. :-)
    If you find some errors please let me know.
    And once again: THANK YOU THANK YOU THANK YOU!
    David
    bruno7 said: see for yourself.
    Would Love to:-) but I am not a fairy and can't guess your URL ;-)
    I know you're not a fairy - that's why I gave you that url in my second comment.
    bruno7 said: I think I've got it right - don't see any white space there.
    davidbauer.cz
    David
    I turns out that maybe I am not a fairy but I am for sure blind :D
    I read your posts 3 times before and I couldn't find it earlier:-)
    I will definitely check your site:-)
    I like your page and your works:-) Everything looks pretty clean :-)
    As I am mostly programmer not designer(Daniel is:-) ) that is all I can say for now.
    I hope you will be happy with your site!
    'Clean' - that's what I like in design and that's the look I was able to achieve on my website thanks to you.
    Thank you again for all your help - I might still need some in the future as now I have to translate the site to English and add few photo galleries. ;-)
    And thanks for complimenting my work - you've made my day!
    Best regards,
    David
    P.S.: Enjoy another Latte & Donut, you deserve it big time! :-)))
    Wow, thanks a lot again!
    If you will stumble somewhere please come back to forum:-)
    Have a nice day!
