I would like an opinion about entitled feature : could an Album being displayed with the layout hidden by default, I find it's giving more impact to showcased works when layout is hidden on arrival. As you ApolloGuys provided enough features to browse pictures without needing much more display, would that be a easy/possible trick to code ? Launching the click function on page complete load ? Or after a very short delay timer 1000ms so that the visitor could see the layout disapearing (= knows it exist) ?
I'll be very happy to have some help about that
Thanks for your attention.
1. Use this plugin http://wordpress.org/plugins/custom-javascript-editor/
2. Go to Appearance -> Custom JavaScript
3. Add this code there: With regards.
In case you doubt, it works flawlessly
I'll en-fat you with donuts for that ahah !
Thanks you so much !
If you are happy with this theme please don't forget to rate us on ThemeForest - it helps us a lot! Thanks!
With regrads.
