Hi
All in one seo settings are always duplicates in all new topics and changed topics. I asked my question first in their support forum and they checked my url and their reply is:
"It looks like your theme may be incorrectly setting the $post_global variable which is interfering with All in One SEO Pack which uses this variable. I recommend contacting the theme developer to see if they can determine whether that variable is being used."
for all conversation
http://semperplugins.com/support/general-all-in-one-seo-pack-pro-forum/seo-settings-of-posts-change-custom-post/#p1704please check.
this variable is not used by our theme.
I don't have full access to this forum so I only see your posts.
Maybe you have some other plugins that can be in conflict with this plugin or you should try on fresh installation and check is this issue will it show up also.
BTW. If you want to see some bugs then enable debug mode and SEO plugin, and try to save changes in post;-)
I disabled all plugins and problem still continue.
Also i completely uninstalled AIOSEO plugin and made fresh installation. Still same.
my url: www.kotgiyim.com
(of course this problem happens only with AIOSEO)
http://imageshack.us/a/img801/2904/screenshot81h.jpg
http://imageshack.us/a/img248/1682/screenshot83u.jpg
http://imageshack.us/a/img849/1629/screenshot84uw.jpg
When i open new topic some settings comes without my demand.
I have logged to your site, but language make it hard to navigate. Anyway I have installed same plugin, not in PRO version, with version number 2.0.2 and I couldn't reproduce your issue.
If you wish to continue, then please:
1. Start new Wordpress installation(in English please)
2. Install theme.
3. Install plugin(only this one!).
4. Try to reproduce your issue.
5. If it is there, then send me login to that installation, and step by step list to reproduce it.
6. Then I will try to reproduce it on my server also, and we could proceed with any fixes.
1.) I deleted all mySQL database
2.) Fresh Wordpress installation. (in english)
3.) Fresh hypershot installation.
4.) Fresh Plugin.
5.) İmported old posts with wp tools.
Login info same...
(if you want to check up SQL database i can send it to you, only 120KB)
I have found what were wrong when this plugin is run in our theme.
Fix will be added in new update(2 days max).
