Discussions
Categories
Home
Beach Please
Contact page on mobile
Eric05
May 2013
edited May 2013
in
Beach Please
For the contact page on mobile, is it possible to have first the form and the map in second, under the form?
Thank you!
Air
May 2013
You can try to change their order in
contact.php
. If it will produce any issues then it is not possible in current layout probably.
Eric05
May 2013
It works. I should use the child theme for this change, shouldn't I?
Air
May 2013
If you like:-) I don't mind.
Eric05
May 2013
I know you don't mind, but to keep the change after an update, child theme is the solution, no?
Air
May 2013
Yes, just as explained in documentation
http://apollo13.eu/docs/beach/#!/modification_of_theme
cris
May 2013
This would be a good change to make in the next version :-)
Having the map show up above the form on mobile devices is a bit confusing...
Air
May 2013
edited May 2013
I will have to see, if it for sure not making any new issues. If not, then I agree:-)
May 2013
Air
June 2013
Done in new version. Will be released today. Sorry for delay!
Eric05
June 2013
Great !
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
114
OneLander
324
PhotoProof
591
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
May 2013
cris
June 2013
Eric05
June 2013
Air
Discussions
Categories
Sign In
contact.php
. If it will produce any issues then it is not possible in current layout probably.With regards.
