The same code here, but on diferent styles...one yellow, one semi transparen....etc etc.
/* BG Color */
.page #content,
.no-results #content{
background-color: #fff;
/* width */
.static-left #content,
.static-right #content,
.static-center #content{
width: 420px;
Yes you can try to write styles for page IDs, same idea as here http://support.apollo13.eu/discussion/982/text-directly-on-background-image/p1
You can see page id in Admin area in address bar, when you edit it(page).
Test firstly, ask if it doesn't work.
If i change this property, The responsive size doesnt work, if theres a solution to that?
thks
Use this custom CSS: With regards.
}. Now it is fixed, so you have to also fix your code with it everywhere you copied it.With regards.
}is what is added there. Then recreate your own code again, cause now your lacking these.With regards.
