Hi after upgrade to Version 1.5 The Top Menue Navigation have the same old Problem. When i want to navigate to another site it shows me that he cant find the side .
Sorry elay. It doesn't seem like theme problem. Rather like some plugin like super cache issues. White are is also not issue, you just don't have enough content for full height and you changed white version to dark so this is effect of incomplete transformation ;-)
1. WP Super chache is deinstalled. 2. The problem with the White Part at the bottom is there since update to 1.5 Before the Update it was not there. 3. I only change the Background Color over your Settings in the Theme ( Background color ).
4. And whats about the "Site not found" Problem over the top Menue ? When i click at the Home or Contact Menue it works but the Categories not This also happend after update.
1. nice 2.Change background-color for html tag in custom css(before you had no problems with content so you couldn't see if there is problem. 4. Change some options in Airlock settings and save(it will clear cache for links). Switch off all plugins, and again clear cache for links)
5. Come back with WP account for me ONLY if it won't help. I really mean ONLY IF :-)
http://support.apollo13.eu/discussion/56/pagination-problem.#Item_13
Point 1
But not the Problem with the Pagination. Only when i click on Top menue i get the Error that the Page cant found.
When you click on the Category Filter Commercial, it seems there is something wrong at the bottom Part ( White Area ).
thanks please need help
I will try the Points.
I really tried a lot like your Description, but nothing changes.
Have still the same problem.
I also noticed that the Arrows are not on the right place ( see attachement )
I send you a WP Account and FTP Account to your mail
thanks
It also works better on your Site ;-)
thanks
I have been on your site, but i have no idea what is going on.
I suppose that some plugin have left mess after it self. Top menu disappear after changing to "issue site". I will look around that clue.
hope you can make it work.
thanks
