thank you for your quick responds. I followed the link and copy the CSS you gave us, obviously changing the size but it doesnt work. I guess I am not doing the right thing though. Where should I insert it? I tried on Appearance>Custom CSS and also Appearance>Editor>at the bottom of the code and they didn't work.
I think I followed the link before I sent you the previous message, but it is not working yet. I have the plugin for Custom CSS, inserted the code you gave us and change premalinks to post name, saved all changes but it hast worked.
You are not alone:-) http://support.apollo13.eu/discussion/1028/how-to-change-the-font-or-font-size-for-photo-names-in-fullscreen-albumss/p1
Where should I insert it? I tried on Appearance>Custom CSS and also Appearance>Editor>at the bottom of the code and they didn't work. Thanks
Thank you
}after styles for footer. Fix it:-)With regards.
much appreciate it
