Shortcode BUTTON strange result
edited May 2013 in Skyfashion Posts: 36
[button text_color="#ffffff" background_color="#b49049" url="http://www.aveleen-avide.com/"] Button [/button]
etwas test
[button text_color="#ffffff" background_color="#b49049"] Aveleen [/button]
mehr text
The above code produces the result attached. Problems:
The button "BUTTON" does not render the full word "BUTTON" centered above "etwas test" but on same hight.
The second button "Aveleen" does not appear.
Any ideas?
    Hi Hughhenry,
    The second button doesn't appear because it doesn't has URL value.
    The first button should appear without any problems. Have you got some plugins installed? or maybe you made some changes in your CSS code?
    WIth regards
    Got that with missing URL - thank you!
    The only CSS changes are (suggested by you):
    #content .post .single-entry-meta p {
    display: none;
    .post_tags, .comments_count {
    visibility: hidden;
    Various plugins installed - you'll see, when you login.
    Cheers,
    Hughes
