In 2 out of 3 cases, video function produces error:
"Video not availbale - more information"
although the clip runs on YouTube without problems and URL is correctly embedded in video shortcut dialog box.
Is there a workaround?
I want to embed:
1.
2.
and the codings are:
1. [video type="youtube" src="
" height="335" width="595" autoplay="off" /]
2. [video type="youtube" src="
Cheers, Hughes
If you want to insert a code on this page you have to use tags < pre > and < code > (without spaces in this tags, like in HTML). Now you inserted some code and it shows a video from youtube. Please insert it in this tags and I will try to find a problem.
With regards
restart:
I want to embed:
1.
This lines comes from documentation
VIDEOS
[video type="youtube" src="MovieID" height="335" width="595" autoplay="off" /]
[video type="vimeo" src="MovieID" height="335" width="595" autoplay="off" /]
MovieID we mean "J4vuF5zkt_8" not a link to youtube
so your code should look like this:
[video type="youtube" src="J4vuF5zkt_8" height="335" width="595" autoplay="off" /]
Try to change it and let me know if it works
With regards
