Hi Air,
contact page doesn't send messages. I have no confirmation"success or failed" after send message, and i receive nothing. It does not work either with above infos section.
I try with contact form 7 plugin and it work fine.
Can you help me ?
Thank's
If you have tested that you Wordpress is sending mails, then it may be other problem. First lets try with live link. If I won't find anything suspicious I will ask for more access.
now it's ok. I just move my site. It was on subdomain and i move on main aera.
thank you !
