Pattern over masonry brick thumbnail
edited June 2013 in Hypershot Posts: 23
hello,
how can i have pattern over brick album layout, but not when "mouse over" but when all thumbs are visible, so opposite from what i have now. now i have pattern when i "mouse over" a photo thumbnail, and i would like to have a pattern over all album photos and when i "mouse over" then the photo would reveal itself.
thanks
    first simple guess (I had a similar "problem" once):
    Look for
    em.cov
    and
    em.cov:hover
    in the style.css and change attributes (like opacity) with the help of the cild theme's css.
    But maybe, there is some javascript helping.... As I said: Just a guess!
    Max
    well i have found the codes you wrote, and managed to get the pattern over brick images but now on "mouse over" i cannot get the clean photo look, and the little magnifying icon is gone.
    any suggestions how to fix that?
    thanks
    Hello
    macmacs as always helpful :-) Thanks ;-)
    nikica try this topic http://support.apollo13.eu/discussion/1006/mouseover-darker-thumbs-in-slider-album-and-brick-theme-to-normal-thumbs/p1
    thanks Air. is there a way to save little magnifier icon when i pass over a photo with a mouse? it is lost now when i applied codes to css.
    Hello
    Can you show result with live link? Then I will try to reply:-)
