Discussions
Categories
Home
Spaceship
Background image on header
mindfulray
June 2013
edited June 2013
in
Spaceship
Hello, I noticed in the Admin that I can change the color of the header, but there's not a place to add a background image, like there is for the body of the site. I'm comfortable with CSS, but unsure where the code for that would go.
Any ideas?
Air
June 2013
Hello
Please use plugin like this
http://wordpress.org/extend/plugins/pc-custom-css/
activate it, and next go to Appearance->Custom CSS. There you can insert your custom CSS. If it won't work be sure to set Permalinks like explained here
http://support.apollo13.eu/discussion/comment/3831#Comment_3831
mindfulray
June 2013
If I install this, will it overwrite all of the existing CSS or will it simply add on to it?
Air
June 2013
Normal style file will be still loaded, so you can change/overwrite parts that you wish:-)
Sign In
or
Register
to comment.
Sign In
Register
Quick Links
Categories
Recent Discussions
Categories
3.7K
All Categories
115
OneLander
324
PhotoProof
591
Rife
40
Agency
130
Starter
886
FatMoon
197
Thirteen
337
Photon
319
Chillout
769
Hypershot
3
General
June 2013
mindfulray
June 2013
Air
Discussions
Categories
Sign In
Please use plugin like this http://wordpress.org/extend/plugins/pc-custom-css/ activate it, and next go to Appearance->Custom CSS. There you can insert your custom CSS. If it won't work be sure to set Permalinks like explained here http://support.apollo13.eu/discussion/comment/3831#Comment_3831
