Layouting shortcode tabs
edited May 2013 in Skyfashion Posts: 36
Compared with SKYFASHION demo - I want to change:
1- left upper corner: having a "clear" corner - getting rid of the small vertical "end of line"
2- having the non-active tabs filed with a light grey
3- getting rid of the small bulletpoint in the upper left corner of each tab
Any ideas? - Thank you & kind regards,
Hughes
    Hi Hughhenry,
    Please tell me - have you modified Skyfashion theme before? Have you got some plugins installed? Please send me a link to your website and i will try to help you.
    With regards
    Hi Argone,
    I didn't modify Skyfashion - yes, there are some plugins.
    Website is not public at the moment - but I can send you URL and login date by PN, if you send me your E-Mail.
    H
    Hi Hughhenry,
    You can send it here on forum via private message(click on my nick and there you will find option to send message) .
    With regards
    Done!
    Hi Hughenry,
    Please send me a link to this page where you tried to insert tabs.
    With regards
    Done... to you PN
    I sent you a link an login date - a week ago - do you have any ideas to help me?
