Hi! Just a quick question:
I inserted a photo with Lightbox in a blog post on my website just now (here's the link so you can see what I mean
http://7188photography.com/blog/2013/06/the-yin-and-yang-of-creativity/)
Problem is, there's this huge white space created under the image as a part of the image, which is really distracting.
Any ideas?
Cheers and thanks for the great support
Yes, when you insetred shortcode you have selected big image version and probably didn't look what dimension it set for you (1100x490px).
Insert smaller image as thumb that points to bigger one:-)
