Problems with Hypershot Albums
edited June 2013 in Hypershot Posts: 3
I am having errors with the hypershot theme on my website. Please see here. http://www.phidel.co.uk/
Whenever I try to load the album it gives me Error 404 (on the lookbook page and campaign page), but one of the albums loads correctly into the homepage. Please could you tell me how to fix this? I have deleted all my albums and created new ones, I have updated the theme.
And the site is due for launch.
Thanks and I will await your response
    Hello
    First try will it work with default permalinks.
    If not then check is it working when all plugins are deactivated.
  • I've tried all I could since yday and before I posted this thread I knew the solution would be something easy, something I just didnt think of. PERMALINKS. Haaaaa. Thank you very much!
    Great it is solved:-)
    Have a nice day:-)
  • Hello again Air Thanks for your help but now i'm trying to embed ecommerce into my site and it isnt looking too great so I decided to go with bigcartel. They have given me the css code to it but my question is how can I embed it into the site and make the bigcartel frontpage load into my site?
    Hello
    This theme wasn't tested with this plugins(?) so it may not work nice. Also I don't have any experience with using them so I will be no help for you.
