What I did:
Editing picture size (text mode) in one singular post (from 459/231 to 484/241... no big deal).
Publish.
What happened:
ALL posts now are reduced to half in width (2 column to 1 column) - aligned left.
All other pages (home, contact form) remained normal as they should be.
Even re-installing style-light.css did not help.
Any ideas??
Thank you very much, Hughhenry
Please send me a link to page with this issue.
With regards
I have sent you a personal mail with login data and issues - Thank you so much for your help!
Hughhenry
Please update Skyfashion to newest version 2.0.
With regards
Cheers!
Updating to 2.0 solved the "posts in half"-problem.
Now I am stuck with the bulletpoint in front of the tab label at tabs.
Please send me a link to page with this problem. I will check what i can do there.
With regards
http://new.hughesschlueter.com/163/tod-in-belval-2-2/
Sent you login data per PN... got it?
