Skype social media icon
edited July 2013 in Hypershot Posts: 69
What is supposed to be entered in the Skype field in order for it to work? I tried to enter "skype:?call" and just the username, but to no avail.
Apologies in advance if this topic is in the documentation and I somehow missed it.
Thanks,
LazyDiver
    Sorry, the username part between the colon and question mark got deleted. I tried to enter skype:username?call.
    All this social links where made for http:// links.
    If you want to work what have you tried, you will have to edit header.php line ~142
    $soc_html .= '<a target="_blank" href="' . esc_url($value['value']) . '" title="' . esc_attr(__fe( 'Follow us on ' ) . $apollo13->all_theme_options[ 'social' ][ 'social_services' ][ $id ]['name']) . '"><img src="' . esc_url(TPL_GFX . '/social-icons/' . $icons_set . '/' . $id . '.png').'" alt="" /></a>';
    to
    $soc_html .= '<a target="_blank" href="' . $value['value'] . '" title="' . esc_attr(__fe( 'Follow us on ' ) . $apollo13->all_theme_options[ 'social' ][ 'social_services' ][ $id ]['name']) . '"><img src="' . esc_url(TPL_GFX . '/social-icons/' . $icons_set . '/' . $id . '.png').'" alt="" /></a>';
    Hope that helps:-)
    Thanks, Air, that worked! :)
