Hide post date in single posts
edited July 2013 in Skyfashion Posts: 36
Hi Argone,
how can I remove the posts date including the frame in certain posts (not all!)? Only in single posts.
As you see there is a conflict with the post title/headline.
I'm sure it can be done with custom fields - but which code do I have do write where (single.php or style-light.css)?
Thank you!
Hughhenry
    Hi Hughhenry,
    add this to your layout.css file in common/css/skeleton folder
    .post_date { display: none; }</pre>
    With regards
