We fixed the blog breadcrumb in a previous post but when assigning a non default name to the portfolio breadcrumb the break crumb url isn't being assigned to the proper page.
Click portfolio breadcrumb here for example.
http://www.h2oaddicts.com/portfolio/san-mateo-2/it's not being assigned to the correct page as selected in: Airborn -> Portfolio -> Select Portfolio
I have used old login data you provided to check things. Sorry for not asking, just wanted to get things done.
As mentioned in documentation http://apollo13.eu/docs/airborn/#!/portfolio point 2
You need to set permalink/slug to portfolio if you use nice addresses. I changed it, and now it works.
Hope that helps.
Home > Portfolio > Name of portfolio
I would like to change the name of portfolio
I have a same trouble !
I want to change Portfolio by References
And when i click on Portfolio i go on 404 error
"Accueil » Portfolio » Black Bird"
The link of the page
http://blog.agence-commilfaut.eu/portfolio/black-bird/
Can you help me, please ?
Have you done http://apollo13.eu/docs/airborn/#!/portfolio step 5?
Tthis problem is only when i'm on my project page
Accueil>> Portfolio>>Black Bird
http://commilfaut.fr/portfolio/black-bird/
When i'm on portfolio page i have this :
Accueil>> Références
http://commilfaut.fr/references/
Thx for support
I think the easiest way will be to not show this on single project page.
Go to functions.php, and edit line 50: to If you like(and are not afraid), you can also edit this line to be static link to your "References" page.
but your lines are similar !!??
