Hello there,
I'm having a difficult time trying to implement qTranslate on the theme's custom fields. Using [:en] or tags on the field when filling up is not working.
I read on qTranslate foruns that it's usually the function is missing a "__()", so it will parse the qTranslate tags.
Can you please help me with that? If i could only make "Subtitles" field translatable using this wTranslate tags would be great.
page is here:
http://www.museunaif.com/wordpressthanks.
I think that none of these fields are displayed using this function as they are not part of layout.
Are you talking about subtitle field of pages? If yes, you can try to edit file
advance\utilities.phpline ~218, and change to But I don't know if it should work that way.With regards.
i used [:en] type of tags of qTranslate : )
Thank you very much!
With kindly regards.
