Hello, I'm wondering if I can change the link to an album list brick to a Page instead of the actual album? I have one project right now that has images, video, and audio and another that needs a link to another web page. Is this possible with a little customization?
This is not easy customization. I know it was asked few times, but I can't remember did anyone achieved such result. You can search for it in Hypershot category, but not sure is it there.
As I said I don't remember if anyone achieved this. This is too big change to do it easily. I will take a look on forum now and post here if I find anything. There is just same topic around yours, just keep your eyes open on topics;-) http://support.apollo13.eu/discussion/1081/how-to-disable-links-on-album-slider-imagess#Item_2
Go to
advance/meta.phpline ~293 and change to Nextalbums-list.phpline ~101change to: Tested, works:-)
Post above is about your main question, so please don't mix it.
how to find lines? Just search for cited code, easy :-) I always use ~mark cause this line can change due to theme updates, or user customization, but in default theme they should be there in same line as mentioned.
With regards
Question. Did that became 'standard' along update or should I go thru too ?
Very nice tweak. Thanks both.
Nope it is not in standard, it just customization on demand :-) So you have to follow this steps :-)
(I can't see a .php file labelled advance/meta so assumed meta was the one?
I don't know what could went wrong cause as you can imagine, it could be everything. Try again, and if it won't help I will try to check what is wrong on your installation.
Sad times as it still won't work - Has their been an update since in the solution was found? Sorry to be a pain. Would you be able to look at it for me?
Thank you
If you want me to do this changes for you(what I don't have time for lately) then send me temporary access to your WP and FTP so I could check there what is going on. Send it here on forum via private message(click on my nick and there you will find option to send message) . In message please attach link to topic it applies to.
Is there a possibility for a option: When clicking a brick-image (in the masonry-style layout) it either shows slideshow (like it does right now) OR redirects to a link. I´d like to use the custom link-option you did in this thread, but for images in albums.
I´ll explain my situation: I´ve got a lot of projects I want to show, and I´m sorting them in the main menu by Web, Print, Illustration and Graffitti. A lot of my projects are just images, but for some I need to show more information, like writing something about it, not just show slideshow images. So I need a page for the project.
EDIT: Oh, I solved it. For anyone else wondering, I set different Album genres and added them as menu items. (see documentation Add Album > Adding multiple Albums list)
