Mouseover Description for Latest Works
edited May 2013 in Skyfashion Posts: 8
here is my page: http://www.xiaolongliu.com/
I want to know how to remove the mouseover effect from the "latest works" elements? and keep the effect constant on the single works? like the example on my attached file.
Thank You for Help
    Hi Skiou,
    Have you got this feature on demo template?
    With regards
    Hi I create the example picture by myself.
    hi Skiou,
    I think that you don't understood my question.
    Have you seen our template demo? If yes - is there this feature?
    With regards
    Skiou,
    I'm sorry, that's my fail for this misunderstanding.
    Recipe for your problem:
    1. Open your file in skyfashion theme: common/css/skeleton/layout.css
    2. Find line with div.slide_box_hover definition
    3. Add line like below:
    div.slide_box_hover {
      display: none !important; //this is additional line
      position: absolute;
      width: 220px;
      height: 150px;
      display: none;
      vertical-align: middle;
    Let me know if it works for you.
    With regards
    Thank you but it doesnt work :(
    I'm now on your website and i see that it works. Maybe you wanted to disable some other option? On main website when i'm moving mouse cursor over projects there is no hover.
    Tell me which hover you want to disable.
    With regards
    oh i think we misunderstand, i want that the hover is always visible.
    can you tell me how to show the hover effect always? even without mouseover.
    push
    Hi Skiou,
    I'm sorry for long time without answer.
    3. Add line like below (or change line from earlier recipe) :
      display: block !important; //this is additional line
      position: absolute;
      width: 220px;
      height: 150px;
      display: none;
    let me know if it works
    hi thanks, but it looks like this: http://i40.tinypic.com/xm798h.png
    Hi Skiou,
    Change above code as code below:
      position: absolute;
      width: 220px;
      height: 150px;
