Dear Support Team...
1. in the Dashboard…how i change the “BP Apollo 13 Theme” in whatever i want?
2. how i can disable the update notification generally? can i do that and manually upload updates without having notifications?
3. Where i change the Name, email, subject, text in contact form with greek characters?
4. How i put Spam protection in contact form.. Save us from spam! + 7 = thirteen ???
Thanks in advanced,
Xrisxal2000
If you have more then one case to talk about then please add every case in separate topic, cause if this topic will have more then 3 answers, it will make chaos by answering to different points of first question. I believe you can imagine this :-)
Now to answers:
1. in
advance/apollo13.phpline ~16 you can edit this stringBP Apollo13.define('TPL_ALT_NAME', 'BP Apollo13'); //alternative name for visuals2. Independent of update notifications you have to upload updates manually :-) You shouldn't see it if you have newest version. However to disable it remove this code fromadvance/apollo13.phpline ~203 3. In translation files:-) http://apollo13.eu/docs/beach/#!/translating_theme You will have to make your own for Greek or edit default one.4. http://apollo13.eu/docs/beach/#!/plugins_recomendations_captcha
Thanks fot the 5stars support!!!
Kind regards,
xrisxal2000
