Hi Greatest Support team ever!!!
Pls how can i add a picture as background color...i mean instead i put
#323232 or what ever i want to have a pic ..ii don't want white or black, i would like to put an image insted of color. How can i do that?? And pls i want to leave the pages menu as it is, i want the background image only for navigation buttons , header, footer.
I would ber eally greatfull if you could hep me with that!!! Kindest regards,
xrisxal2000
If you want to put image behind some element use CSS Please show me on screen shot behind what elements you want to set images and I will give you CSS selectors.
and i put it in..custom.css??
Thanks Air!
Thanks Again!
Then you should put your images for header and footer. And yes use full picture URL Hope that will help you.
pls see image!!!
http://webex.gr/pic.jpg
Thanks x 1000!
how i add the backgound image to the menu
menu background color...this pic you say....thanks Air!!!
Try this for menu With regards.
Really Air, you help me a lot . And super Fast!!!
Thanks Air, yes i will change it.
I really appreciate your effort
Kindest regards,
xrisxal2000
I know that always you make the best, and that is more than enough, regardless time!!
Thanks,
xrisxal2000
