How do I create a Gallery with slider in my blog like your Hypershot Blog Demo?
LtdLtd
edited August 2013 in Hypershot Posts: 2
First let me start by saying thank you for creating the fabulous hypershot theme. It is just what I had been looking for. Now if I can just get two of my fave features to work, I will be in hypershot heaven☺
Info as you’ve requested:
1.Link to site: http://jockstarzzblog.com
2.List of Active plugins: Akismet, GoDaddy Quick Setup, Jetpack by Wordpress, Welcome to Wordpress
3.Wordpress Version being used: 3.6
5.Have I made any code modifications? No, ..foreign language to me lol:)
I’d like to create a GALLERY with slider post exactly like the one in the your hypershot Blog Demo. I’ve tried doing this by 1) selecting “Gallery”under the Format Drop down button 2)uploading images via the the add media button 3) Selecting “Slider” under Gallery Settings 4) Setting Link to “None” and 5) Setting Gallery Type to “Slideshow”, however, once I publish, the images are actually not in a GALLERY with a slider but instead publish as separate images.
Instead of getting this: *see attached first two screenshots from your hypershot blog demo
I’m getting this:
Blog home page with GALLERY test post: http://jockstarzzblog.com
Expanded GALLERY test post: http://jockstarzzblog.com/?p=196
This is what happens when you click on separate images:
*also see attached screenshots from my blog
Similarly, I’d also like to create a PAGE with a slider like the one in the hypershot Demo. I thought I would be able to do this by simply selecting “Page with slider” under the Template drop down box, however my only selection options are Albums, Archives, Contact and site map. Need guidance on this as well
Thanks in advance for your help:)
    First - thanks for kind words:-)
    Second - If you have more then one case to talk about then please add every case in separate topic, cause if this topic will have more then 3 answers, it will make chaos by answering to different points of first question. I believe you can imagine this :-)
    Back to questions:
    Ltd said: ’d like to create a GALLERY with slider post exactly like the one in the your hypershot Blog Demo
    It is totally different process.
    First you have to create album http://apollo13.eu/docs/hypershot/#!/adding_album_add_new_album
    Next you get to your post where you wish to use slider and select Album slider under Post media, and next select you created album http://apollo13.eu/docs/hypershot/#!/adding_new_posts_pages
    Done:-)
    Ltd said: Similarly, I’d also like to create a PAGE with a slider like the one in the hypershot Demo.
    Could you link to example? Maybe you just wish to see album in slider view?
    Anyway I advise you to check some of our documentation:-)
  • LtdLtd
    Success! Thanks you for your assistance. I finally got both features to work:-)
