Wordpress gallery scaling in iPhone.
edited August 2013 in Skyfashion Posts: 3
Hi! Thanks for a great theme. I have problems using the WP-gallery. It will not scale responsivly in iPhone it just squeezes the images to a thinner format. Here´s a link http://www.ylvaskarp.se/galleri/
I probably do something wrong. The gallery seems to scale or adapt to the iphone if I switch theme to the standard wp-ones.
Best regards
Magnus
  • Is it possible to make "works" portfolio apperar twice on the same site to solve this issue?
    Please :)
    Hi magnus,
    Have you got any configuration on WP gallery? there you have inserted a static height of photo. Could it be from gallery configuration?
    Kind regards
  • Hi Argone, thanks for your reply.
    I don´t know... I just used the standard wp-gallery, I only chose how many columns displayed. I´ll try and find where the static height can be altered.. thank you
