Hi
I have 3 questions regarding the Hypershot theme:
1. my images are showing the image name at the bottom when in album mode - how do i get rid of the image name
2. how do i change the grey textured background to white?
3. my brick album option sometimes shows 4 columns and sometimes 5 - and when i change the size of the bricks in pixels, it doesn't seem to respond...?
Thank you for your help.
Kind regards,
Michelle
First some info: Title of topic is not much informative. In future please describe topic in title.
If you have more then one case to talk about then please add every case in separate topic, cause if this topic will have more then 3 answers, it will make chaos by answering to different points of first question. I believe you can imagine this :-)
Back to questions:
1. Just don't add this names:-) Show live link please.
2. You can set in Appearance menu of theme http://apollo13.eu/docs/hypershot/#!/appearance_menu
3. Info how bricks behave http://apollo13.eu/docs/hypershot/#!/albums_menu_albums_list_appearance_bricks_theme_
Please try set edge values to check if theme really doesn't respond to settings.
