body.blog #content{Actually I use the child theme, and i tryed to add this css entry in the user.css and the style.css in the child directory but it still takes the user.css from the non-child directory.
background-color: black;
Are you editing user.css by finger? If yes then stop it;-) It is made out of settings from panel so it will rested every time some settings are changed.
Read how to edit CSS in theme http://apollo13.eu/docs/hypershot/#!/modification_of_theme_changing_css
If you are trying to overwrite something that is set in panel then better set it in panel ;-) or use stronger CSS selector.
I added: in the style.css child's theme folder...
On last question:
I would like to remove this short black line under the top menu. I can't finde the element.
Thank you.
To answer your question:
Use this CSS With regards.
