Hi ! How do I change the height of the buttons and make them closer one to the other ? Also how do I make the space from navigation to logo smaller ? thanks.
maren10 said: Also how do I make the space from navigation to logo smaller
You can reduce padding-top and margin-top, both takes now 20px each. Use this CSS:
#access{ padding-top: 0; margin-top: 0; }
About getting menu items closer, then you have to remove icons you have added to them. I see that you switched them off in appearance settings, but that switches off only loading of CSS.
padding-topandmargin-top, both takes now20pxeach. Use this CSS:#access{About getting menu items closer, then you have to remove icons you have added to them. I see that you switched them off in appearance settings, but that switches off only loading of CSS.padding-top: 0;
margin-top: 0;
