indeed, i already found this topic and tried to change this css rule.
but, there is not enough place for the icons.... and the last one is under the line:). i tried to find a solution but i really do not understand how to change the css.
I think that my pb is with css rules. i tried pc-custom-css and nothing change. i still have an icon (the googleplus icon) which is under the others icon.
I must increase the width of the parent div but i do not succeed to do it responsivly.
Use this CSS http://support.apollo13.eu/discussion/comment/3317#Comment_3317
Icons for socials has 24x24px so this is most you can get from them and it will still look nice:-)
website : c-quemener.com
ty
ced
ty
ced
it's ok for the height. but the third icon (google plus) is still under the two others icon. And i need it on the same line
we don't see the third icon but with firebug or if you reduce ce size of the window, you'll see it.
ty
advance\apollo13.phpline ~31 try to changedefine('SOCIAL_ICON_WIDTH', 20); //Margin included20to bigger number, probably 28 should be ok. Unfortunately it is some old school way of defining width for JavaScript :-SWith regards.
ty
