I've uploaded the update but had to remove it due to the following problems:
In previous version I had a black background that does not display in the new version (white instead of black). In the blog section, the font of the filter buttons does not show up (white on white?). In the album, the portrait photos are cut.
All this was working in previous version but not with the update though none of my settings were changed. So I had to put the backup back on.
As these options are set in the admin panel, I tried re-saving the previous settings I had. But that doesn't seem to work in the new version. I then switched back to the previous version of the theme without changing any of these settings, and my black background re-appeared.
I cannot send you the live link to the updated version as I had to move back to the previous version due to these problems.
OK, so if this is only background color issue please update again and if it still wont work just add this custom CSS in plugin I have linked and come back to me so I could check what is going on.
1. Live link:-)
2. Where you did your changes - in
style.cssorcompressed.css? If yes then you lose them according to documentation.Better use:
a) child theme like explained here http://apollo13.eu/docs/hypershot/#!/modification_of_theme
b) or plugin like this http://wordpress.org/extend/plugins/pc-custom-css/ activate it, and next go to Appearance->Custom CSS. There you can insert your custom CSS. If it won't work be sure to set Permalinks like explained here http://support.apollo13.eu/discussion/comment/3831#Comment_3831
3. Maybe just file with user settings didn't recreate, so you should go to you admin panel and change some settings and save.
I think it is rather 2. option:-)
But previous version can be found here. http://lisabphoto.ch/
Kindest regards,
CSS to use just in case: With regards.
Kindest regards,
