Image set as background on blogs page also appears on album page
edited October 2013 in Hypershot Posts: 69
Hello Air,
I set an image as a background on my blogs page while I left this option blank on my albums page so that the default background would appear. However, that same image also appears on my albums page.
Could you please guide me in fixing it?
Thanks in advance for your help.
LazyDiver
    Hi there:-)
    I see there is indeed issue. I will check why there is conflict and will respond here later.
    Thanks for reporting this.
    Hello
    To fix this go to use this albums-list.php file(see attachment). Fix will go with next update.
    zip
    zip
    albums-list.zip
    1K
  • Hi Air,
    That worked, thanks!
