Hello Again,
i have two questions,
first i would like to chnage or disable the pattern in the caption background, i just couldnt find it...
#slide-text.
The other question i would have is how to alter the Addthis-toolbox. I want to show only facebook and twitter, disable the email and print functions. I cannot alter them in the plugin so i guess its written in the theme, just couldnt find it.
Thanks again!
Michael
1.This topic should be helpful http://support.apollo13.eu/discussion/comment/2404#Comment_2404
also to disable pattern image there use this custom CSS If you want change image of pattern search for
#slide-text
in style.css2. While developing this I also couldn't get this to be changeable from plugin settings. Finally I had to set it to use 5 favourite user ways of sharing. As far as I get it, they are 5 favourite ways of current viewer, so it sounds good in my opinion :-)
How to Edit (add)this?
1. Use uncompressed scripts http://apollo13.eu/docs/hypershot/#!/advance_menu_use_compressed_js_amp_css.
2. Edit
js\uncompressed\album-view-full.js
line ~1908 3. Change above according to this table http://support.addthis.com/customer/portal/articles/381263-addthis-client-api#rendering-decoration-classes4. Save :-)
Thanks a lot, thanks for the super fast answer.
i will have a couple of questions since i decided to update again....But to this one: Since i didnt want all the sharings on my pictures, instead only facebook and twitter i needed the uncompressed js function and it worked fine....Now you guys changed it so we cannot use the uncompressed feature. How should i change the sharings icons (doesnt work from the plugin), or is the only possibility not to use Addthis?
Thanks again,
Michael
Changes are the same, but file is no longer in
uncompressed
directory but level upjs\album-view-full.js
.With regards.
the new thing is, that albumlists have now social buttons from addthis aswell...could you tell me where i find them?
Thanks again,
Michael
js\script.js
line ~1911 You do it same thing there.With regards.
