Black color scheme
edited October 2013 in Hypershot Posts: 19
hi there,
1st of all GREAT THEME!!!
I´ve one question concerning the black Color scheme: when I use the black Color scheme, I also want the Header/info and the footer(+thumbnails list in the slider) in black, like they are when I use the White Color scheme ;-) ...
is there an easy way, for example commenting out some lines in the css file for the black Color scheme, so that the Header/info and footer stay black like they are when using the Default/White Color scheme
thx for answering
best regards
    hi there,
    perhaps there is an easy way for others who need this too, I´ve now just deleted all tags concerning Header and footer in black.css with the help of firebug
    Hello there:-)
    Great you made it without my help. You solved it in good way:-)
  • edited November 2013 Posts: 36
    I switched to white color scheme. Is it possible to change show info white backgroud color to black with custom CSS? I want ot keep the white scheme because of the white blog content.
    Thank you!
    Post edited by Yield on
    Then copy interesting you parts of CSS from black.css to your custom CSS:-)
    After few hr i finally figured it out :)
    Thx!
