Changing page background
edited February 2012 in Airlock Posts: 3
Hello! We launched a blog beta based on your theme at www.nilmasblog.com, and did some customization (like adding fixed block post box height, clickable excerpts etc.), but I still can't figure our one thing: how i can I change the background of a content area of a single page? The easiest solution I've found so far is using QuickStyle background plugin (http://zouak.com/2011/04/03/quickstyle-background-shortcode/), which allows the usage of shortcodes such as [quickstyle_background div='content' style='url("http://www.nilmasblog.com/blue/") #ff0'], which is perfect except for "content" div colors the area outside of what I actually need. Could you help with that? Thanks in advance.
Oh and, though you position your theme as portfolio it actually works wonders as a music blog solution, so thumbs up.
    Hi there.
    If I get you right then fix is simple. Add such style to your CSS:
    body.page #content{
    background-color: #FFFF00;
