switch off icons in blog
edited November 2013 in Hypershot Posts: 17
hellohello
where would i switch off the icons next to titel in the blog pages? would tthe text inherit the added space?
thanx, honcho
  • edited November 2013 Posts: 17
    ok, this works:
    .post-icon{ display: none; }
    .brick h2.post-title,
    .brick .real-content{
        padding-left: 0;
    hmm, and the date? should move over too
    Hi there:-) If you are so good with CSS use Firebug or other tools hidden under F 12 key, to detect what CSS should be changed:-)
    To move date use this
    .date_n_author {
    padding-left: 0;
    thanx. did that, and looks fine in overview of blog entries.
    but when you follow the link into the post the date moves to "padding 0" whereas the rest, titel and content, stays on old position.
    .date_n_author{ padding-left: 0; }
    .real-content{ padding-left: 0; }
    h1.post-title{ padding-left: 0; }
    ok!
    a detail, but details are important:
    on loading, for a split second the icon and the old (original) css still come in play. what would I have to do in the php to get rid of that?
    many thanx
    Please post link where I could see your issue.
    sent by pm
    Indeed it is visible, very strange.
    Go to single.php line ~22 and remove
    <span class="post-icon"></span>
    from
    <div class="date_n_author"><?php echo a13_date_and_author(); ?><span class="post-icon"></span></div>
    perfect, thanx!
