i was wondering if it is possible to replace the header image for the contact page with custom code.
For example an Google maps piece of code.
Right now it is a still image but I would love to implement the code generated by Google maps.
Current situation:
http://www.pilipili.be/2011/contact/Thanks in advance!
Hi there.
Nice way of using top image ! :-)
About your question.
Contact page have special template in our theme. If you edit your contact page and choose proper template like in here http://trevordavis.net/images/content/2009/02/wordpress-page-template.png You could then go and edit airlock/contact.php file
Find line~13
<div id="post-<?php the_ID(); ?>" <?php post_class('contact-page'); ?>>And there above it you could add
and insert in your google code.
