"Latest works" on two rows
edited November 2013 in Skyfashion Posts: 4
section "Latest works" in home page for some browsers is shown on two lines insted only one as usual. Problem is there only for some browser like IE 9 or Firefox 25 for example.
In attachment you can see a screen-shot for the problem that affects also your template demo page.
Could you please help me to find a way to show "Latest works" section on only one row?
Many thanks for the support,
VIA Art Project
  • I forgot to advise that the problem is there only when I change the content font to "Tahoma" as shown in the screen-shot.
    Many thanks,
    VIA Art Project
    Hi
    Could you send me a link to your webpaage?
    Kind regards
  • Hi Argone,
    I wrote you a private message with all details.
    Many thanks,
    VIA Art Project
    Ive got your priv msg. Could you send me temporary login data to your wordpress too? I will check your internal configuration ASAP.
    Kind regards
  • Hi Argone,
    Many thanks,
    VIA Art Project
    I sent you prv msg with resolved problem.
    Kind regard
  • Hey Argone could you give the public solution. Its not a support website if you send private message at each message !!
    Thx !!
    sangana
    Its true :) Sorry for that:
    Find div.slide_box in file common/css/layout.css and add a property like that:
    div.slide_box {
    ... (code which is in file)...
    float: left;
    Kind regards
  • Hello Argone,
    Thx again !
    Regards.
