Website doesn't look fine at all in IE8
edited November 2013 in Hypershot Posts: 19
Hi!
It seems that there is an issue with IE8 view. The site is under construction but I've attached some screenshots how it should be and how it looks on IE8 (I have my thoughts on IE, but it seems some people is stiil using it...). Is there a way to fix this or prompt visitors to upgrade there IE version?
Thank you in advance.
Anne-Sophie.
    Hello
    Thank for screen shot, but linkS would be real help in this case.
    Upper part of screen shot: have to take a look what the code is.
    Lower part of screen shot: looks like it is cause by using semi transparent color as background.
